PROBLEM
Logging off a Citrix session does not close ArcMap
Last Published: April 26, 2020
ArcMap is not being closed immediately when the the Citrix session is terminated.
Cause
This behavior is a known Citrix issue and is referenced by Citrix Document ID: CTX891671.
Solution or Workaround
Warning:
The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary.
Esri cannot guarantee results from incorrect modifications while following these instructions; therefore, use caution and proceed at your own risk.
Add a new string value entry with the following parameters to the registry key in the Citrix server's registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Citrix\wfshell\TWI
Value Name:LogoffCheckSysModules
Type:REG_SZ
String:ArcMap.exe
Additional applications can be added to the string by entering a list of executable names using a comma and no spaces between them. For example:
String:ArcMap.exe,ArcCatalog.exe,notepad.exe
    Article ID:000006679
    Software:
    • ArcMap 8 x
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
