PROBLEM
Auto Complete Polygon task fails to create a new feature
This article pertains to ArcGIS versions 9.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
A new feature is not created when using the Auto Complete Polygon task to create a new feature adjacent to existing polygons.
Cause
The Auto Complete Polygon task uses only the features in the current visible extent.
Solution or Workaround
Pan or zoom in the map so that all polygons adjacent to the intended polygon are visible.
    Article ID:000006677
    Software:
    • ArcMap 9 x
    • ArcMap 8 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
