English
Error: fatal error: can't map library libfor.so
Error Message
Attempting the ArcSDE post installation at 9.2 version with the sdesetup command displays an error message similar to the following:
"28225: /u03/sde/sdeexe83/bin/sdesetupora9i: /sbin/loader: fatal error:
can't map library libfor.so"
Attempting the ArcSDE post installation at 9.1 version or prior with the sdesetupora9i or sdesetupora8i commands displays an error message similar to the following:
Cause
The required Fortran libfor.so library file cannot be found on the computer.
Solution or Workaround
Install the required libfor.so library file for the Tru64 operating system. See the link for the ArcSDE System Requirement page for the Tru64 platform in the Related Information section below.
    Related Information
