English
How To: Copy an ArcIMS site from a development machine to a production server
Summary
Instructions provided describe how to copy an ArcIMS site from a development machine to a production server. If a development machine is used to create ArcIMS sites and a production server is used to publish them to the Web, the following steps must be followed before publishing a site.
Procedure
If the production environment's machine name, URL, or both, are different than what was used when creating an ArcIMS site in the development environment then the following changes are necessary.
  1. Update the map configuration file.
    1. Make sure the *.axl file and its referenced data are accessible from the production server. If necessary, copy them to the according location on the production server.
    2. In a text editor, open the *.axl file
    3. Verify that the path to the <WORKSPACES> is pointing to data locations accessible from the production server. Change the value if necessary, for example:
      <WORKSPACES>
      <IMAGEWORKSPACE name="imageworkspace" directory="<full_path>"/>
      <SHAPEWORKSPACE name="shapeworkspace" directory="<full_path> />
      <SDEWORKSPACE name="sdeworkspace" directory="<full_path> />
      </WORKSPACES>
    4. Save changes and close the file.
  2. On the production server, update or create the according map service.
    1. On the production server, login to ArcIMS Administrator or ArcIMS Service Administrator.
    2. Create or update a corresponding map service.
    3. Point to the updated *.axl file.
    4. Make sure the name of the map service is identical with the name on the development machine. Mapservice names are case sensitive.
    5. Verify the map service property Server Output HTTP Location points to the fully qualified name of the machine; for example: http://mymachine.esri.com/output
    6. Create the map service.
    7. Save the Site configuration and close the application.
  3. Update the Web site.
    1. Copy the created Web site folders from the development machine to the according Web site directory on the production server.
    2. In each copied Web site directory based on the HTML Viewer, open ArcIMSParam.js in a text editor. Change the imsURL and imsOVURL variable values to use the fully qualified machine name.
      Example:
      var imsURL = 'http://mymachine.esri.com/servlet/com.esri.esrimap.Esrimap?ServiceName=acetate';
      var imsOVURL = 'http://mymachine.esri.com/servlet/com.esri.esrimap.Esrimap?ServiceName=acetate';
    3. Save your changes.
    4. In each copied Web site directory based on the JAVA Viewer, open default.axl in a text editor.
      Change the URL attribute values for the IMAGESERVERWORKSPACE and/or FEATURESERVERWORKSPACE tags to reflect the fully qualified URL. Save and close the default.axl file.
  4. In a Web browser, launch the Web site with the fully qualified domain name to check if it works correctly.
    Example: http://mymachine.esri.com/website/test
Related Information
