English
Bug: ArcSDE Java API issue #1 with Oracle Java Virtual Machine
When running ArcSDE 8.x Java API applications as Oracle Java Stored Procedures, the application hangs the Oracle session. The session cannot be killed and the Oracle service cannot be shutdown (shutdown immediate) normally. The only option available is to shutdown abort.
Cause
The ArcSDE Java API application hangs on the SeConnection.close() method call.
Workaround
Download 8.3 QFE for ArcSDE Java API and Oracle JVM issues through the link in Related Information, below.
Related Information
