Frequently asked question
Why doesn't the supplied code unlock the extension when registering ArcPad StreetMap?
Answer
It is likely that an incorrect authorization code was entered in the registration dialog box.
[O-Image] AP Streetmap Screenshot
Common scenarios are:
* An incorrect Device Key Number was entered when obtaining the authorization code at http://myesri.com/ArcPadstreetmap/
Be sure to use the Device Key Number displayed in the registration dialog box on your device.
* The data authorization code was entered instead of the extension authorization code. Keep in mind both the extension and the data must be registered. Be sure to enter the correct authorization code in each respective registration dialog box.
Article ID:000006582
Software:
  • ArcPad Prev
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
