HOW TO
Check the ArcView or ArcEditor Single Use authorization number by command line
Summary
Instructions provided describe how to use the command line to check the ArcView or ArcEditor Single Use Authorization number.
Procedure
  1. Open a DOS prompt from Start > Programs > Accessories > Command Prompt.
  2. Change directory to the install location of ArcGIS. For example:
    ArcGIS 8.x:
    Code:
    C:\>cd C:\ArcGIS\arcexe8x\bin
    ArcGIS 9.0:
    Code:
    C:\>cd C:\Program Files\ArcGIS\bin
  3. Run the 'registerfixed' command as follows:
    ArcGIS 8.x:
    Code:
    C:\ArcGIS\arcexe8x\bin> registerfixed /query
    ArcGIS 9.0:
    Code:
    C:\Program Files\ArcGIS\bin> registerfixed9 /query
    The ArcView or ArcEditor Single Use registration number displays.
Article ID:000006575
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
