PROBLEM
Cannot view the attributes of an SDE layer with ArcGIS
No records are returned when opening an attribute table in ArcMap or previewing an attribute table in ArcCatalog.
Cause
The Oracle database is out of temporary tablespace.
An error message may not be returned in ArcMap, ArcCatalog, or SDE, but an error message indicating the problem appears in the Oracle alert log.
Solution or Workaround
Increase the temporary tablespace in Oracle.
Article ID:000006561
Software:
  • ArcMap 8 x
  • ArcMap 9 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
