English
FAQ: How does the Oracle SDO_GEOMETRY example COLA_MARKETS work with ArcSDE?
Question
Answer
In the Oracle COLA_MARKETS example, the first feature is an optimized rectangle. ArcSDE versions before version 9.0 will not autoregister a layer that has an optimized rectangle in the first row. If using a version of ArcSDE earlier than version 9.0, remove the first feature from the example. The resulting Oracle SQL is as follows:
Code:
CREATE TABLE cola_markets (
mkt_id NUMBER(38),
name VARCHAR2(32),
shape MDSYS.SDO_GEOMETRY);
INSERT INTO cola_markets VALUES(
2,
'cola_b',
MDSYS.SDO_GEOMETRY(
2003, -- 2-dimensional polygon
NULL,
NULL,
MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,1), -- one polygon (exterior polygon ring)
MDSYS.SDO_ORDINATE_ARRAY(5,1, 8,1, 8,6, 5,7, 5,1)
3,
'cola_c',
MDSYS.SDO_GEOMETRY(
NULL,
NULL,
MDSYS.SDO_ORDINATE_ARRAY(3,3, 6,3, 6,5, 4,5, 3,3)
INSERT INTO USER_SDO_GEOM_METADATA
VALUES (
'cola_markets',
'shape',
MDSYS.SDO_DIM_ARRAY( -- 20X20 grid
MDSYS.SDO_DIM_ELEMENT('X', 0, 20, 0.005),
MDSYS.SDO_DIM_ELEMENT('Y', 0, 20, 0.005)
NULL -- SRID
CREATE INDEX cola_spatial_idx
ON cola_markets(shape)
INDEXTYPE IS MDSYS.SPATIAL_INDEX;
commit;
The table must be registered with ArcSDE. Manually register the SDO_GEOMETRY layer with ArcSDE using the 'sdelayer' command.
Code:
sdelayer -o register -l cola_markets,shape -e a -c mkt_id -C user -u . . .
For version 9.3, there are some changes in the sde commands to register the layer, an example is pasted below:
C:\Documents and Settings\bisw0000>sdelayer -o register -l cola_markets,shape -e a -C mkt_id,user -t SDO_GEOMETRY -P BASIC -u sde -p sde -i 6161
ArcSDE 9.3 for Oracle10g Build 508 Thu Apr 17 12:23:18 2008
Layer Administration Utility
Successfully Created Layer.
If the data was autoregistered, and it does not display in ArcCatalog, refer to the article in Related Information on how to unregister autoregistered third-party Oracle Spatial tables.
Related Information
