English
Error: An unhandled exception of type 'System.Runtime.InteropServices' occured in the xxx.exe
Error Message
When exporting with ArcPress in a standalone application, the following error may occur:
"An unhandled exception of type 'System.RUntime.InteropServices.COMException' occured in the WindowsApplication1.exe"
Cause
The system variable path isn't pointing to the ArcGIS bin directory.
Solution or Workaround
Set the system path variable.
  1. Navigate to Control Panel > System > Advanced tab > Environment Variables > System Variables.
  2. Under System Variables, double-click path.
  3. Set the variable value to point to the ArcGIS bin directory:
    C:\arcgis\arcexe83\bin
    Be sure to include a semi-colon to separate entries. For example:
    C:\SomeOtherApp\bin;D:\arcgis\arcexe83\bin
