English
Problem: Rasters projected on-the-fly disappear when the data frame is rotated
When a raster layer is projected on-the-fly in ArcMap, and the data frame is rotated, the raster layer disappears.
Cause
Double transformations applied to a raster.
Solution or Workaround
Follow these steps to prevent the raster layer from disappearing:
  1. Project the raster to the projection system of the data frame.
  2. Add this projected raster to the data frame.
  3. Rotate the data frame.
Related Information
