English
FAQ: What operation codes are supported for the GSI format in the Survey Analyst importer?
Question
Answer
The following is a list of all operation codes as well as those that are not supported:
0: No Index
11: Point Number 110006+00000001 Point number 6, Point name 1)
21: Horizontal Angle 21.102+21530400 (102->gon, Ha = 215.30400)
22: Vertical Angle 22.102+09969170 (102->gon, Va = 99.69170)
31: Slope Distance 31..00+00170702 (00->meters, SD = 170.702)
32: Horizontal Dist 32..10+00063466 (10->meters, HD = 63.466)
33: Height Difference
41: Code Number
58: Reflector Constant
71: Remark
72: Remark
73: Remark
74: Remark
75: Remark
76: Remark
77: Remark
78: Remark
79: remark 79....+10310000. '1031' displays in the Remarks Field of the TPS Measurement.
81: Target Easting
82: Target Northing
83: Target Elevation
84: Station Easting
85: Station Northing
86: Station Elevation
87: Reflector Height
88: Instrument Height
12: Instrument Serial Number (Not Supported)
13: Instrument Type (Not Supported)
18: Time Format 1 (Not Supported)
19: Time Format 2 (Not Supported)
42-49: Info (Not Supported)
51: Constants(PPM&MM) (Not Supported)
59: PPM (Not Supported)
