English
Error: ORA-00920 invalid relational operator
Error Message
When ArcCatalog is used to register a feature class as versioned, the following error code is returned:
"ORA-00920 invalid relational operator"
Cause
The Oracle parameter STAR_TRANSFORMATION_ENABLED is set to TRUE.
The Oracle parameter is set to TRUE by default when installing an Oracle database using the Data Warehouse template.
Solution or Workaround
Set the Oracle parameter STAR_TRANSFORMATION_ENABLED to false.
Refer to Oracle documentation on how to set parameters for the database.
    Related Information
