English
How To: Limit the display of a Geostatistical Analyst layer to values that are within the threshold range of the layer
Summary
A Geostatistical Analyst layer can be displayed to only show those areas that are within the default range of threshold values.
Procedure
  1. Right click the Geostatistical Analyst layer and select Properties.
  2. Select the Symbology tab.
  3. Select the Show option to be modified.
    [O-Image] GA layer symbology properties
  4. Click the Classify button.
  5. Uncheck the Data Exclusion Lower and Upper Threshold options.
    [O-Image] GA layer exclusion
  6. Click OK on the Classification dialog.
  7. Click OK on the Layer Properties dialog.
Related Information
