Answer
The Zipper Task is an ArcObjects Developer sample that can be used to help close gaps between polygons in a feature class. Instructions on how to install and use this tool can be found in the ArcObjects Developers Help under the Contents tab > Samples > Editing > Edit Tasks > Zipper Task.
