English
Error: ArcGISFMEDataSource: Error in FMEDataSourceUtils::Session
Error Message
The following error may occur when starting ArcMap:
Error:
Cause
A customization installed by Safe Software's FME Suite 2003X2 cannot find a license. This can occur even if the FME Suite was removed, because the uninstall procedure sometimes fails to properly unregister the custom .dll file.
Solution or Workaround
Either register or renew the licensing for the FME extension for ArcGIS or unregister the FME extension's dll.
  • Option 1: Register or renew the FME Suite by contacting Safe Software. See the Related Information.
  • Option 2: Unregister the <FME_HOME>\application_extenders\arcgis\ArcGISFMEDataSource.dll.
  1. Start up a command prompt:
    1. ​Click Start > Run > type cmd.
    2. Click OK.
  2. In the command prompt, type regsvr32 /u <path>\ArcGISFMEDataSource.dll
<path> is the path to this file. By default, the file is located in \application_extenders\arcgis\ArcGISFMEDataSource.dll.
Related Information
