English
How To: Share folder connections in ArcCatalog with other machines
Summary
Universal Naming Convention (UNC) allows a path to be identified without specifying a drive letter. For example:
\\ComputerName\Folders\Paths\file.doc
The instructions provided in this article demonstrate how to use UNC paths to share ArcCatalog folder connections with other machines on a network.
Procedure
  1. Add the Location toolbar to ArcCatalog by selecting View > Toolbars > Location.
    For ArcGIS 10.x, select Customize > Toolbars > Location.
  2. Type the full UNC path into the Location text box and press Enter.
    [O-Image] ArcCatalog location text box
  3. Close ArcCatalog.
  4. Open Windows Explorer and navigate to:
    %USERPROFILE%\Application Data\Esri\ArcCatalog
    For ArcGIS 10.x, navigate to:
    %USERPROFILE%\AppData\Roaming\Esri\Desktop10.x\ArcCatalog
  5. Copy and paste the ArcCatalog.gx file to the same directory on another machine.
