English
Problem: java.lang.IllegalArgumentException: argument type mismatch
While trying to use the method getThematicMap with the ColdFusion MX toolkit, the following error appears:
"Could not perform web service invocation 'getThematicMap' because java.lang.IllegalArgumentException: argument type mismatch"
Cause
There are two methods named getThematicMap. If one is invoked and then the other, the ColdFusion toolkit tries to request the first method and fails.
Solution or Workaround
Delete the stubs and restart the ColdFusion Server. Do this each time when switching between getThematicMap methods.
