English
Error: Run-time error '-2147024882(8007000e)': Out of memory
Error Message
When projecting a shapefile using the ArcView Projection Utility as an extension, clicking the Finish button on the Summary dialog box returns the error:
"Run-time error '-2147024882(8007000e)': Out of memory"
Cause
This is a known issue with the Projection Utility on XP.
Solution or Workaround
Two options are:
  • Install the ArcView 3.x Windows XP Patch from the web link provided in the Related Information section.
  • Run the ArcView Projection Utility by clicking Start > Programs > ESRI > ArcView 3.x > Projection Utility.
Related Information
