English
Error: java.security.AccessControlException: access denied (java.util.PropertyPermission NLS_LANG read)
Error Message
Creating a connection to an ArcSDE server using an ArcSDE Java API Applet application run inside a Web browser returns the error:
"java.security.AccessControlException: access denied (java.util.PropertyPermission NLS_LANG read)"
Cause
The operation is restricted by Java security specification for applets that are loaded over the network. An applet cannot read certain system properties.
Solution or Workaround
The ArcSDE Java API applet application and the ArcSDE Java API jar file must be deployed as Java extensions. Refer to the tutorial and documentation from Sun Microsystems on creating and deploying Java extensions in Related Information below.
    Related Information
