English
FAQ: Is it possible to write an applet with the ArcSDE Java API?
Question
Answer
Yes, the ArcSDE Java API can be used to develop applet based applications. However, the ArcSDE Java API requires access to resources that applets loaded over the network cannot access. Because of this, both the ArcSDE Java API applet based application and the ArcSDE Java API jar file must be deployed as Java extensions.
Please refer to the tutorial and documentation from Sun Microsystems on creating and deploying Java extensions.
Related Information
