BUG
If a floating point grid is used as the <source_grid> for COSTALLOCATION, COSTDISTANCE and COSTBACKLINK, an error message similar to the following will appear:
"Grid: costalloc = COSTALLOCATION(srcgrd_flt, costgrd)
Source_grid SRCGRD must be of integer type to be used for allocation values.
Cost Distance mapping Failed
AML MESSAGE - Stopping execution of AML file due to ERROR condition"
The Workstation documentation indicates that the <source_grid> can be integer or floating point for COSTALLOCATION, COSTDISTANCE and COSTBACKLINK. This is not correct.
Floating point grids are not supported as input for the source grid.
Get help from ArcGIS experts
Download the Esri Support App
