HOW TO
Instructions provided explain how to create a white background using ArcPlot or ArcTools. When creating a map with ArcPlot or ArcTools, it is sometimes necessary to use a box fill that is white.
In ArcPlot or in an AML, use the following commands to draw a white box, which will print white in the final product:
Code:
shadedelete all
shadeset color.shd
shadesymbol 1
shadecolor white
patch <* | xmin ymin xmax ymax>
Using ArcTools, the same effect can be achieved with the following steps:
Go to Map > Properties and change shadeset to color.shd.
Draw the shaded box in the desired location, selecting shadesymbol 16 and shadecolor white.
Get help from ArcGIS experts
Download the Esri Support App
