English
Error: java.io.IOException: Emitter failure.
Error Message
While using the com.apache.axis.wsdl.WSDL2Java class file to create wrapper Java classes for an https service, the following error occurs:
java.io.IOException: Emitter failure. Invalid endpoint address in port IAuthentication in service XXX
Additionally, the generated XXXLocator.java file is blank.
Cause
Using the following generic command doesn't work:
Java org.apache.axis.wsdl.WSDL2Java –o .\src –p com.esri.is.servicestests.axis.stubs XXX.wsdl
Solution or Workaround
Use the following optional parameter to correct the problem:
Java -
Djava.protocol.handler.pkgs=com.sun.net.ssl.internal.www.protocol org.apache.axis.wsdl.WSDL2Java –o .\src –p com.esri.is.servicestests.axis.stubs XXX.wsdl
