PROBLEM
When using displayLayers to turn additional layers on, the layers do not appear on the map and no error is generated.
The map layers are not available at the given extent. For instance, when viewing the entire United States, the ZIP code layers will not be available.
Get help from ArcGIS experts
Download the Esri Support App
