Summary
Instructions provided are for placing text on a map using the MarkerDesc object with a label parameter and without an iconDataSource parameter.
Procedure
By leaving the iconDataSource parameter value null, a text-only label is placed on the map.
Parameter names are slightly different in v2.
Follow the steps below to create a MarkerDesc object with defined values for label and location parameters.
- Create a MarkerDesc object.
- Set the value of the label parameter with the text wanted on the map. For example, "My coffee shop".
- Set the value of the location parameter with the coordinates of where the text should appear.
- Do not set the value of the iconDataSource parameter (leave it null). This places the text on the map without an accompanying icon.
- Assign the MarkerDesc object to a MapImageOptions object.
- Create a LabelDesc object if customizing text.
