Right-click the main layer name and click Properties. The Properties dialog box opens. Select the Layers tab. Select a sub-layer name, then click the up or down arrow to change the order and click OK. The order of the sub-layers cannot be changed by clicking and dragging.
Note: To get the properties of a specific sub-layer, select the sub-layer, right-click, and select Properties from the pop-up menu.
