Answer
When using the Sampling Tool in the PLTS Data Reviewer it will allow you to choose layers for the sample set that are not set to selectable. If you choose layers that are not set as selectable the tool will automatically set the layers as selectable so it can create the sample set. If you do not want these layers to remain as selectable you must uncheck them from the Set Selectable Layers Tool.
Article ID:000006363
Software:
- ArcGIS Production Mapping
