Frequently asked question
When I add or remove layers from my TOC the Attribution Center flashes repeatedly.
Answer
It is recommended that you close the Attribution Center before adding or removing multiple layers from the TOC. The Attribution Center will flash repeatedly and this may take some time because it rebuilds itself each time a layer is added or removed. It is important that you open the attribution center again after it is done, because it will affect your editing if it is closed.
Article ID:000006357
Software:
  • ArcGIS Production Mapping
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
