ERROR
GifRenderer: No color compression was necessary.
Error Message
The "GifRenderer: No color compression was necessary" message may be found in the ArcIMS spatial server stdout log files, when using an ArcIMS service that produces GIF output images.
Cause
This message indicates that when trying to produce an 8-bit GIF image from 24-bit image data that no color compression (or color loss) was necessary, because the imagery data used 256 or less colors.
Solution or Workaround
Nothing needs to be done. This message is for information only, and does not indicate a problem nor require any action.
    Article ID:000006347
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
