English
Problem: 1002: Internal error occurred in the Web service
A request to Route Finder Service returns the following error:
"1002: Internal error occurred in the Web service"
Cause
There isn't a valid route between the stops. For example, attempting to route from Hawaii to a location in the continental United States will cause this error because it is not possible to drive between these points.
Solution or Workaround
Select route stops that are on the same street/ferry network.
    Related Information
