English
FAQ: Can I automatically connect to the ArcWeb Toolbar 1.0 when opening ArcMap?
Question
Answer
Yes. You can automatically connect to ArcWeb Services each time you open ArcMap by setting to true the RECONNECT_AT_ARCMAP_START value in your login.xml file. To change this value, open your login.xml file in a text editor and set the RECONNECT_AT_ARCMAP_START value to True.
<RECONNECT_AT_ARCMAP_START>True</RECONNECT_AT_ARCMAP_START>
Related Information
