English
How To: Programatically add a mapped font to a PDF export
Summary
Instructions provided describe how to take a TrueType font in the map and export it out to a mapped font using the code below.
Procedure
Make certain to specify the font to map. The following code can be used in conjunction with existing code used to export map to .pdf file.
Code:
'This section maps the TrueType Font to a Mapped Font
Dim pFME As IFontMapEnvironment
Set pFME = pExporter 'QI to already exisitng pExporter object
Dim pFMC As IFontMapCollection
Set pFMC = pFME.FontMapCollection
Dim pFont As IFontMap2
Set pFont = New FontMap
pFont.Mapping("Arial") = "Courier"
Debug.Print pFont.MappedFont
pFont.SetMapping "Arial", "Courier"
pFMC.Add pFont
Debug.Print pFMC.Count
