HOW TO
Save and reuse stops, barriers, and pushpins.
Summary
Stops, barriers, and pushpins are stored in an XML document with a .GRF file extension. Use this document to archive, reuse, or share your stops, barriers, and pushpins with others.
Procedure
To create a new GRF file:
1. Open or create a map (.apm file) containing a StreetMap layer with the desired stops, barriers, and pushpins.
2. Tap StreetMap Options and tap the Locations File tab.
3. Type the name of the new GRF file in the Location of the grf file text box and tap OK.
To load an existing GRF file:
1. Open or create a map (.apm file) containing a StreetMap layer.
3. Select the desired GRF file in the Location of the grf file text box and tap OK.
Article ID:000006306
Software:
  • ArcPad Prev
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
