English
Problem: Some generated stops are not showing up in the map.
After selecting a new Locations file (*.grf) or opening a new map containing a StreetMap layer, some stops are not displayed on the map.
Cause
Stops that fall outside the area of the local StreetMap dataset are not displayed on the map since they cannot be used in routing or geocoding.
Solution or Workaround
Extract a new dataset that covers the geographic area of all stops using the Data Extractor.
