PROBLEM
When adding a StreetMap layer via the Open ArcPad Map dialog box, the extent of the layer displayed is incorrect.
The Open ArcPad Map dialog box, which is accessed via the Open Map command, is only intended to open ArcPad Map documents (*.apm) or layer formats supported by ArcPad out of the box.
Get help from ArcGIS experts
Download the Esri Support App
