English
How To: Change the selected object in ArcCatalog using VBA
Summary
This article contains a code sample that shows how to change the selection in ArcCatalog using VBA.
Procedure
  1. Start ArcCatalog.
  2. Open the Visual Basic Editor.
    In ArcCatalog, select Tools > Macros > Visual Basic Editor.
  3. In the Project Explorer window, expand Normal.gxt. Expand ArcCatalog Objects and right-click ThisDocument > View Code.
    [O-Image] ArcCatalog Project Explorer
  4. Copy the following code into the code module:
    Code:
    Sub ChangeSelectionInArcCatalog()
    Dim pGApp As IGxApplication
    Dim pGxSel As IGxSelection
    Dim pEnumGxObj As IEnumGxObject
    Dim pGxObj As IGxObject
    Dim ln As Long
    Set pGApp = Application
    'Specify the file that is to be selected
    'In this case it is a personal geodatabase table
    Set pGxObj = pGApp.Catalog.GetObjectFromFullName _
    ("c:\testing\table.mdb\accidentdata", ln)
    Set pGxSel = pGApp.Selection
    pGxSel.SetLocation pGxObj, Nothing
    'Refresh the catalog.
    'By setting the path it will only refresh that folder
    pGApp.Refresh "c:\testing"
    End Sub
  5. Close the Visual Basic Editor.
  6. Run the code.
    A. In ArcCatalog, select Tools > Macros > Macros to display the Macros dialog box.
    B. Select a macro and click Run.
