ERROR
Starting the Data Extractor and loading a dataset from a network drive yields the following error:
"Can not load file
AProjectManagerImpl: setProject failed
Undefined error in line 130 of file aDETProjectManagerImpl.cpp".
The dataset was installed to run from the network, but the network drive is accessed from a Uniform Naming Convention (UNC) path; for example: \\ServerName\ShareName\. A mapped network path must be used instead; for example: X:\StreetMap Data.
Get help from ArcGIS experts
Download the Esri Support App
