English
Problem: StreetMap extension not available and numerous VB script errors occur
After installing ArcPad 6.0.1 (or later) and ArcPad StreetMap, the StreetMap extension is not available in ArcPad and VBScript errors are reported.
Cause
This and similar issues are likely caused by conflicting versions of ArcPad on the Windows CE device. In addition, VBScript errors frequently indicate issues with VBScript support on the device.
Solution or Workaround
Uninstall any older versions of ArcPad before installing the latest version. Then, install StreetMap.
If VBScript errors persist, install the VBScript Runtime Library for Windows CE that is provided with ArcPad.
