English
How To: Toggle the visibility for a LYR or group layer legend using ArcObjects
Summary
Instructions provide a code sample that shows how to toggle the visibility of the Table of Contents legend for a group layer or LYR file.
Procedure
  1. Start ArcMap.
  2. Create a new UIButtonControl: How To: Create a new UIButtonControl​
    For more information on creating a UIControl, see the ArcGIS Desktop Help topic: 'Creating custom commands with VBA and UI Controls'
  3. Right-click the UIButtonControl and select View Source.
  4. Copy this code into the UIButtonControl's click event.
    Code:
    Dim pMxDoc As IMxDocument
    Dim pGroupLayer As IGroupLayer
    Dim pLayer As ILayer
    Dim pLegendInfo As ILegendInfo
    Dim pLegendGroup As ILegendGroup
    Set pMxDoc = ThisDocument
    Set pLayer = pMxDoc.SelectedLayer
    If Not TypeOf pLayer Is IGraphicsLayer Then
    If TypeOf pLayer Is IGroupLayer Then
        Set pGroupLayer = pLayer
        pGroupLayer.Expanded = Not pGroupLayer.Expanded
    Else
        Set pLegendInfo = pLayer
        Set pLegendGroup = pLegendInfo.LegendGroup(0)
        pLegendGroup.Visible = Not pLegendGroup.Visible
    End If
        pMxDoc.ActiveView.Refresh
        pMxDoc.UpdateContents
    End If
  5. Select a layer file in the Table of Contents and press the button to test the code sample.
