Summary
When an ArcIMS Spatial Server machine is rendered unavailable or removed from an ArcIMS configuration, an ArcIMS Administrator displays the following warning message during every admin session:
"ArcIMS Spatial Servers are not available on one or more machines. View a detailed description of this warning message in the message console."
Procedure
If these Spatial Server machines are meant to be removed permanently from a site's configuration, then delete its reference and save the new site configuration by executing the following commands from the command line prompt:
java com.esri.aims.admincore.cmd.Exec http:\\<machine_name> <admin username> <admin password> cmd REMOVEUNAVAILABLEMONITORS
java com.esri.aims.admincore.cmd.Exec http:\\<machine_name> <admin username> <admin password> cmd SAVE
where
http://<machine_name> is the host machine
Admin username is the name used to log into ArcIMS Administrator or Manager.
Admin password is the password used to log into ArcIMS Administrator or Manager.
