PROBLEM
.NET application stops executing but does not produce an error
When running an ArcObjects application written in Visual Studio .NET, the code stops executing, but does not return an error.
Cause
Exception handling needs to be added to the application.
Solution or Workaround
The C# and Visual Basic .NET code samples show how to add exception handling to the application.
  1. C# exception handling
    Code:
    try
    //Code that might cause an error
    catch (Exception ex)
    MessageBox.Show(ex.Message);
    finally
    //cleanup code goes here
  2. Visual Basic .NET exception handling
    Code:
    Try
    'Code that might cause an error
    Catch ex As Exception
    Finally
    End Try
Article ID:000006253
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
