PROBLEM
The Auto-Complete Polygon Tool will not perform the same functions in ArcGIS 8.3 as it did in version 8.2. For example, creating polygons inside existing polygons was easily done using this tool in version 8.2, but this task cannot be completed using version 8.3.
The Auto-Complete Polygon Tool performed a number of different operations depending on the data. For example, it planarized overlapping polygons, exploded multi-part polygons, and cut existing polygons. It also performed its original intended role of creating new polygons from existing boundaries. Attempts were made to correct this logic at 8.3, but some features were removed
Get help from ArcGIS experts
Download the Esri Support App
