HOW TO
ArcWeb Services contains common objects used by multiple Web services. For example, the Route Finder Web Service implements a Geometry object, as does the Map Image Web Service.
Instructions provided describe how to use an object returned from one Web service as an input request parameter for another Web service, when developing an application using .NET 1.0 and 1.1 technology.
When developing an application that consumes ArcWeb Services using a pre-2.0 .NET technology, it is not possible to directly use an object returned from one service as an input for another service. This is due to how these early versions of .NET deal with namespace organization.
The VB.NET code below must be built upon in order to function properly in your solution. Not all required object properties have been set in an attempt to maintain brevity and focus on this document's purpose.
Code:
' return route from Route Finder service
myRouteInfo = myRouteFinder.findRoute(myRouteStops, myRouteFinderOptions, myToken)
myRouteGeometry = myRouteInfo.routePath
myRouteSimplePoints = myRouteGeometry.points
ReDim myMapSimplePoints(myRouteSimplePoints.Length - 1)
' Loop thru points in route line geometry
' and create a mirror map image
' SimplePoint array
For i = 0 To (myRouteSimplePoints.Length - 1)
Dim myMapSimplePoint As New mapimage.SimplePoint()
myMapSimplePoint.x = myRouteSimplePoints(i).x
myMapSimplePoint.y = myRouteSimplePoints(i).y
myMapSimplePoints(i) = New mapimage.SimplePoint()
myMapSimplePoints(i) = myMapSimplePoint
' build the Map Image geometry object
Dim myParts(0) As Integer
myParts(0) = 0
myMapGeometry.points = myMapSimplePoints
myMapGeometry.parts = myParts
myMapGeometry.type = 2
myMapLineDescription.geometry = myMapGeometry
Dim mldsc(0) As mapimage.LineDescription
mldsc(0) = myMapLineDescription
myMapImageOptions.lines = mldsc
' return map that includes the line
' geometry from the Map Image service and
' display it in the application
myMapImageInfo = myMapImage.getMap(myEnvelope, myMapImageOptions, myToken)
Image1.ImageUrl = myMapImageInfo.mapUrl
Get help from ArcGIS experts
Download the Esri Support App
