English
FAQ: What coordinate system functionality that is supported by ArcSDE is not supported by MapObjects-Java?
Question
Answer
The following projections are not supported in MapObjects—Java:
Projection Description           Number
Krovak Oblique Lambert           43039
New Zealand Map Grid             43040
Aitoff                           43043
Hammer Aitoff                    43044
Flat Polar Quartic               43045
Craster Parabolic                43046
Bartolomew Times                 43048
Vertical Near Side Perspective   43049
Also, the Canadian Transformation CanTrans (NTV2) and the Australian and New Zealand counterparts using NTV2 are not supported.
