English
FAQ: Why does the Create Report option produce a blank report?
Question
Answer
There is an incompatability with the current printer driver.
Select one of the options below to work around this problem:
-- Change the default printer driver to a non-existent dummy printer that does not cause a conflict. See the link in the Related Information section below.
Alternative printers can still be used if they are specifically selected in the printing dialog box.
-- Update the current default printer's driver to a newer version.
-- Set the default printer to a different existing printer that does not show a conflict.
Related Information
