English
Problem: Unable to create ArcMap Services using WebSphere servlet engine
ArcMap Services cannot be created when WebSphere is the servlet engine.
Cause
If the Web server and WebSphere are installed on separate machines, it is not possible to create ArcMap Services.
Solution or Workaround
Install WebSphere on the same machine where the Web server resides.
    Related Information
