English
Problem: PDF output from an ArcMap Service GET_LAYOUT request contains jumbled labels
ArcMap Server supports PDF output for the GET_LAYOUT request. In some circumstances, particularly for splined text, labels of the PDF output appear jumbled.
Cause
The DPI setting may not be high enough. DPI is set in the IMAGESIZE tag of the GET_LAYOUT request.
Solution or Workaround
Increase the DPI setting in the GET_LAYOUT request to 300 or greater.
    Related Information
