ERROR
Failed to rename selected object(s). [Invalid characters in the object name.]
Error Message
When renaming an object in ArcCatalog, the following error message appears:
"Failed to rename selected object(s)
[Invalid characters in the object name]"
Depending on what is being renamed, the message may also contain one of the following phrases:
"The table name is invalid
The dataset name is invalid
The topology name is invalid"
Cause
The new name of the object contains characters that the underlying database considers invalid. The list of invalid characters differs depending on the database.
Solution or Workaround
Rename the object using characters that are valid for the underlying database. A list of invalid characters can be obtained with the following macro. Select the Geodatabase within ArcCatalog and run the macro, a message box listing the invalid starting characters and invalid characters will be displayed.
Code:
Public Sub GetInvalidCharacters()
Dim pApp As IGxApplication
Dim pGxObj As IGxObject
Dim pGxDB2 As IGxDatabase2
Dim pSDEWS As IWorkspace
Dim pSQLSyntax As ISQLSyntax
Dim strInvalidChr As String, strStartingInvalidChr As String
Set pApp = Application
Set pGxObj = pApp.SelectedObject
If TypeOf pGxObj Is IGxDataset Then Set pGxObj = pGxObj.Parent
'If for some reason we're not connected to a GDB, Exit
If Not TypeOf pGxObj Is IGxDatabase2 Then Exit Sub
Set pGxDB2 = pGxObj
Set pSDEWS = pGxDB2.workspace
Set pSQLSyntax = pSDEWS 'QI
strStartingInvalidChr = pSQLSyntax.GetInvalidStartingCharacters
strInvalidChr = pSQLSyntax.GetInvalidCharacters
MsgBox "Invalid Starting Characters: " & strStartingInvalidChr & vbCrLf & "Invalid Characters: " & strInvalidChr
End Sub
    Article ID:000006201
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
