English
Error: java.lang.NoClassDefFoundError: com/esri/sde/sdk/client/SeException
Error Message
When attempting to connect to ArcSDE in Author and having the connection hang, the following error is found in the Message Console:
at com.esri.cc.cat.s.d(Unknown Source)
at com.esri.cc.cat.s.run(Unknown Source)
at java.lang.Thread.run(Thread.java:512)
To enable the Message Console, see the Related Information article below.
Cause
The aimsauthor script included with the ArcIMS 4.0.1 installation on UNIX platforms references incorrect ArcSDE jar files.
Solution or Workaround
Modify the aimsauthor and aimsdesigner scripts to reference the correct ArcSDE jar files.
  1. Navigate to <ArcIMS Installation Directory>/ArcIMS/bin and open the aimsauthor script in a text editor.
  2. Scroll to the end of the file and change the reference of "jsde82_sdk.jar" and "jsde82_sdkres.jar" to "jsde83_sdk.jar" and "jsde83_sdkres.jar", respectively. It will look like:
    $JAVA_HOME/bin/java $Options -cp $JARHOME/jaxp.jar:$JARHOME/parser.jar:$JARHOME/arcims_aej.jar:$JARHOME/arcims_resaej.jar:$JARHOME/esri_mo10.jar:$JARHOME/esri_mo10res.jar:$JARHOME/arcims_author.jar:$JARHOME/arcims_resauthor.jar:$JARHOME/jsde83_sdk.jar:$JARHOME/jsde83_sdkres.jar:$JARHOME/jai_codec.jar:$JARHOME/jai_core.jar:$JARHOME/mlibwrapper_jai.jar:$JARHOME/jcert.jar:$JARHOME/jnet.jar:$JARHOME/jsse.jar com.esri.aims.author.Main
  3. Navigate to <ArcIMS Installation Directory>/ArcIMS/bin and modify the aimsdesigner script using the same steps above.
Related Information
